Hi,
I haven't even mounted the focus motor yet.
When I just put in the coupling, it runs smoothly. When I tighten the coupling onto the focus rod, it gets jammed - I cannot move it at alle except if I use a lot of force.
And again: I know it sounds like I tighten the focus lock, but I don't. If you look at the video, I posted, you will see I explained the problem as I show it on the telescope.
Regards
