I have a problem with the latest version of the ASCOM 6.5.18 driver, my asi290mm camera does not work with maximDl. The program connects to the camera but does not read the image. After rolling back to the 6.5.14 driver, everything works fine
https://bbs.astronomy-imaging-camera.com/d/16786-ascom-asi-camara-driver-v6518-not-downloading-image
I see that the problem has already been reported and is repeatable. I only have a problem with asi290mm, my second camera asi533mc pro works properly
It may be a different problem from the ASI174MINI, would you like us to check this problem remotely?
Hi, of course, suggest the date and time of the call
lukaszkruszka We released the new version ASCOM driver (V6.5.19), could you try that first? we solved the problem of ASI174MINI. thanks.
https://www.zwoastro.com/downloads
