Hello. Recently I realized that even with guiding (separate guiding scope) my image slightly shifts during 2-3 hour session. This happens because of differential flexure (my fixture is not sufficiently rigid). I needed to check the accuracy of scope guiding. I used ASIImg_V1.9.1. I picked a bright star and set autorun as follows: Light exposure 0.5 sec, 120 frames, Delay Between 60s. The intention was to capture frames of a bright star every minute during 2 hours and calculate the guiding error.
The problem is that there was no delay between frames, so all 120 frames were taken in about 1 minute. Even if I check [x] Delay First (it is not clear from UI if it controls only the first delay or both delays) I did not get delay 1 min between frames.
Is this a bug or I am doing something wrong?
Thank you.
