Hello!
I'm using the ASI120MC-S with ASILive on both an older Windows 7 Laptop and a NUC with the newest Windows and a fresh install. The camera is connected through the original USB cable directly to the computer.
The camera works fine with Sharpcap, but when I use ASILive 1.9.1, I get a black bar in the lower part of the image. This happens often when I start the software, but not always. I've tested exposure times between 10 and 30 seconds for EAA.
I can get rid of the bar by turning 2x2-Binning on and of. Then it works as expected, and the background is the same all over the image.
Is this a known behaviour, or maybe some information-overlay which I accidentally activated? The bar stays even when I change the histogram, so I guess it is not caused by a mouse hover overlay...
The camera is in our local observatory about a one-hour-drive away, so it may take some time to test ideas for a solution.
Thank you very much,
Alex
