Hi Sam,
I did another installation test on my HP EliteBook 840. I'm glad to say that it worked (even if I do not know why it did not work before, maybe a few reboots and installation/deinstallation were necessary ?).
For the installation, Demo3 Intel USB3 ext. controler driver installation does not work, I had to install the latest C220 driver version (Intel(R) USB 3.0 eXtensible Host Controller v2.5.3.34) from Intel website - see https://downloadcenter.intel.com/SearchResult.aspx?lang=fra&keyword=Intel%28R%29+USB+3.0+eXtensible+Host+Controller
Tests results, on desk, are good, they speak for themselves:
Camera / resolution / FPS achieved / Overclock:
120MM-S / 1280x960 / 74 / 30%
120MM-S / 1280x960 / 59 / 0%
120MM / 1280x960 / 34 / n/a
120MM-S / 800x640 / 115 / 30%
120MM-S / 800x640 / 89 / 0%
120MM / 800x640 / 71 / n/a
120MM-S / 640x480 / 152 / 30%
120MM-S / 640x480 / 117 / 0%
120MM / 640x480 / 111 / n/a
USB Traffic is not limited, and the FPS varies for both cameras during preview/acquisition (it seems to vary more for the ASI120MM).
Please note that I could not make the ASI120MM-S work on one out of 4 of my USB ports (maybe because that port does not deliver enough power ?).
It looks like the noise on the 120MM-S is a bit less than for the 120MM, do you confirm ?
Thanks for your support, know time to test it on field, but Uranus and Neptune do not require fast FPS ...
Marc
http://astrosurf.com/delcroix
