Hi I have the OAG-L attached to my 36mm filter wheel with a 2600. My scope is an Askar fra 500 and has cones as adapters which range from 68, 54 and 48mm. My OAG-L is connected to the 48mm adapter on the scope. I would like to remove the 48mm and use the 54mm adapter but the OAG-L has a 48mm tilt plate. Will the 54mm or 68mm tilt plate from zwo fit on the OAG-L? I notice that the 68mm and 54mm plates all seem to point to the older 68mm OAG which is no longer around. There is no requirement for backspace due to the design. Thanks
