Hello.
I recently bought an Asiair mini.
Asiair can be powered from a 12V source or from a USB-C port. The USB-C port is also used to transfer data from ASIAIR to a PC. However, it is not clear whether it is safe to use the USB-c port to transfer data while powering ASIAIR from a 12V source. Will this cause damage to the PC or ASIAIR over the power lines? Does ASIAIR provide automatic switching between 5 and 12 V power supplies?
