Guiding line graph at bottom of screen does not appear when in video recording.
I have read in many forums a number users when imagining planets actually baby sit the hand controls to move the planet image back to the centre of the screen when starts to drift. I sure that ZWO, could easily program the guide scope line graph to appear on the screen in video mode. Surely, if one has a guide scope set up their scope then it should be or could be used for centring planets. It is not in use then why not. Some will say perfectly balanced mount etc will give reasonably centring which is true for most times but there will times when one must still manually move the planet back to the centre of ROI/gravity.
The program is there but users should be ab3le to access it
