Astars23 Clearly I've missed a step. Any suggestions on getting it to calibrate before guiding?
In the Guiding window, there is a vertical set of buttons on the right side. The top icon looks like a target inside an x-y coordinate(no idea what it is meant to mean). Tap on that before starting guiding:
The little window that shows "Guide Star" above turns into a display that shows a blue/red set of orthogonal lines. There is also a small button in it that says "Clear" (if memory serves). Tap on that to clear any existing calibrations.
When you rnext estart guiding, ASIAIR should now first perform guide calibrations.
For a system that is meant for rank beginners, the ASIAIR is lacking of useful documentation.
