I am in the process of connecting my imaging equipment using Ethernet network.
I have been able to run ASIair app on my M2 Mac quite easily.
Last night I tried connecting SkySafari 6 to my ASIair Plus to view the location the scope is pointing, It connected and I am pleased the SkySafari program could also control the Gemini II controller.
I am curious to know if it is better to connect both the ASIair and Sky safari independently to Sky Safari or:
Would it be better to connect to the ASIair Plus to the Gemini II controller, then connect SkySafari to the ASIair Plus.
While I was using it with SkySafari connecting to the ASIair Plus last night I found, after a minute or so the ASIair would disconnect from the mount and just pass thru the connection from Sky Safari.
In my experience Sky Safari was much more responsive to control the Gemini II, The ASIair Plus has a few additional features to control the mount.
I will appreciate any experiences from others with experience with this type of setup.
Thank You
aruckle
