HI Sam
Just had a thought with a further question.
I used the fisheye lens last night and got the stars focussed on the screen of my laptop, but I didn't understand/know how to set up the capture. I was using Sharpcap.
Can you clarify what I need to set the fps figure to and what to set the Frame Divider to?
I assume the frame divider, if set at say 20, will mean the software will write 1 in 20 frames to the capture file. And thus when these frames are played back as a video the image will be seen 20 times faster than real time?
Also, if exposue is set at 2 seconds, presumably fps have to be less than 2?
Thanks for helping
Alec
