After testing Station Mode in 5G(Hz) Wifi mode, I'm unable to make the Seestar go back to a Station Mode Network in 2.4G WiFi. 1.9.1 iOS app, newest firmware.
In order to switch the WiFi frequency, you need to end station mode. When I do this, the app displays a message that it will reconnect automatically, but that always fails. Next time I reconnect, I can ideed change the frequency back to 2.4G. But when I then switch on the Station Mode again, the Seestar apparently switches back to 5G by itself: it connects to the last Wifi network it was connected to, which happens to be the 5G network I tested earllier, and all the other displayed Wifi network alternatives are also 5G networks, Indeed when checking the WiFi frequency setting, it has then reset itself to 5G !! There is no way I seem to be able to get back to a 2.4 G network :-(
Anyone else seeing this ??
