I recently bought a ASI2600MC pro and had couple of sessions with it no problems. But this weekend I was trying to get started with another one but encountered a problem. I started seeing elongated stars. I have read numerous discussion regarding this and I can come up with couple of reasons this could happen:
- issue with back focus
- camera tilt
I kind of want to rule out back focus as it's well established for my setup its 55mm. I have this optic train:
ED102CF->HoTech 2" Field Flatterner->Spacer Ring(21mm)->Spacer Ring(16.5mm)->ASI2600MC PRO
So my setup has 21 +16.5+17.5 = 55mm
and this setup has been working for me, at least two weeks since I bought the new camera.
The second issue that I suspect could be camera axis tilt as my HoTech gets inserted into adapter ring I feel that might not be aligned properly as it has 3 knurled screws that needs to be adjusted. Or It could also be the Camera itself, I am not sure.
My question is - how do I find out the cause for the elongated stars? I tried to adjust the adapter ring but its not changing anything.
I would appreciate if somebody could point me to right direction to fix this issue.
Thanks
Vikram
