What is the best adaptor to power the ASIAIR Plus through an electrical socket? 12V 3amp or 12v 5amp?
I want to be sure I won't damage the ASIAIR Plus with too much current..
Thanks, Jerry
5A will be better. You won’t damage due to the higher current. This is the maximum current the power supply can give. The ASIAIR will only take what it requires.
I use a 10A and a 5A…. Amperage over 5A is good and makes no difference as the Asiair or whatever you are using just uses what it needs.
