Dear All,
please help I do not know what I am doing wrong. When I finish stacking almost black image comes out. No adjustment helps. It worked fine on some DSO such as C33 and C34. But when I want to stack M31 it is not working. The image is black. I use ASI 294MC PRO. I do not know what to do.
Thank you.
Kind regards,
Martin
SFhsRlCS Could you send some fits files for analysis? You can share them via google drive or other cloud drive if they are too large. thanks.
JohnD
johnpd
@"Tech@ZWO" https://drive.google.com/drive/folders/13kpXKHLMD54K6V8tE2_8pX2b2Q4cZjv3?usp=drive_link
SFhsRlCS I tried the images you sent, work fine. Did you check all frames if there are some bad images? some bad images may cause a problem like this, and our devs are working on it now.
Could you stack only the eight frames you sent?
Tech@ZWO So finally I found it. It was one wrong dark image. It was totally white. How can this happen? Thank you for paying attention.
