jimv Sorry i did not make it clear, i mean a single frame, not the fit file after stack.
I believe I did post a single frame (in FITS format) and not the result of a stack of frames. Could you please explain why you think otherwise?
Also, I neglected to ask why you are suggesting I change power supplies since the cooler is off when capturing video. It is my understanding the power supply need not even be connected particularly when capturing video. Is this incorrect?
Finally, regarding the prominent horizontal banding visible on the moon disk (but not so evident on the dark sky), I have been doing some daytime videoing which clearly shows the horizontal banding exists across the entire sensor frame.
