Great. Thanks.
A few more things I came up with when using it yesterday.
- Some option to limit rotation of the device when it is plugged in. I had it plugged in to an external battery when attempting a timelapse. It lost the sun, and I hit the button again to have it search. After it failed, I went outside to find the cord was wrapped multiple times around the base of the device. If it is plugged in, rotation up to 360 degrees each direction (maybe 270, but minimal testing should reveal which is better) is probably fine. After that, it should rotate all the way back and approach the angle from the other direction (similar to a meridian flip) to avoid pulling the cord.
- An option to go "home" without powering off. This is directly related to the cord wrapping thing, but I'd like to have it return to the home az angle (alt isn't so important) so I can plug it in knowing it isn't at some odd angle that's going to cause issues and then I can go back to whatever I was doing.
If there's a better spot for feature requests, let me know. I'll keep toying with it and will probably have lots more ideas.
