Grettings,
This is Alex, from Barcelona. I have been testing my new equipment (SC8 and ASI120MM). I get some beautiful images of the moon. I had a guiding camera for planetary imaging for a while but now everything is easier. ;)
I have a Lunt35ha, too. When I image the Sun in Ha I get this lines:
Capturing:
Stacked:
Proccessed:
Video:
http://www.youtube.com/watch?v=PdsffNjumDI
Firecapture log:
Scope=Lunt35Ha
Camera=ZWO ASI120MM
Filter=L
Profile=SolHa
Filename=SolHa_050714_Gain=38_Exposure=.6ms_Gamma=98_180527.avi
Date=050714
Start=180527.566
Mid=180542.966
End=180558.367
Duration=30.801s
Date_format=ddMMyy
Time_format=HHmmss
LT=UT+1h
Frames captured=779
File type=AVI
Extended AVI mode=false
Compressed AVI=false
Binning=no
ROI=1280x960
FPS (avg.)=25
Shutter=0.592ms
Gain=38
USBTraffic=80
AutoExposure=off
Brightness=0
Gamma=98 (off)
Histogramm(min)=113
Histogramm(max)=153
Histogramm=60%
Noise(avg.deviation)=18.20
Limit=none
Sensor temperature=47,8 ∞C / 118,1 ∞F
Unfocused image:
I have been playing with settings and I get the same results. However, if I adjust exposure to get the prominences, the lines disappear:
As I said, no problems in the moon or planets. I get this lines even changing USB wire, rotating the star diagonal or camera, changing between ASI120mm and Nexi5, using Sharcap, Firecapture, iCap... The problem is the telescope, I guess.
Some help here? Thanks in advanced.
Alex
