Very nice! Just 2 notes:
1) it looks like there are some vertical bands on the Trifid. Is the nasty "vertical noise reduction non kicking-in" problem striking back? :-(
2) it seems that you have some coma. Look at the starts in the upper left and right corner of the Trifida (or rotate left by about 90° in M16). I'm plagued with a similar problem, if you align the newton with a Cheshire, it's not sure that the sensor of the ASICam will be centered too. So, for the next YAACA release, I'm planning a function to measure the "roundness" of a star. Then I'm planning to use this plus an artificial star to do the alignment directly wit the ASICam mounted: this should more reliable.
What Delta T you get with your mod?
BTW I'm attaching my best M20, unfortunately it's very low where I observe (and versus south I have 2 big cities with a lot of IL :-( ): M20, CLS filter , 30 x 60" of lights e darks, ASI120MC cooled, 6" f/4 GSO
