See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.TypeInitializationException: The type initializer for 'TiGra.Diagnostics' threw an exception. ---> System.Configuration.ConfigurationErrorsException: Configuration system failed to initialize ---> System.Configuration.ConfigurationErrorsException: Unrecognized configuration section system.serviceModel. (C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Config\machine.config line 134)
at System.Configuration.ConfigurationSchemaErrors.ThrowIfErrors(Boolean ignoreLocal)
at System.Configuration.BaseConfigurationRecord.ThrowIfParseErrors(ConfigurationSchemaErrors schemaErrors)
at System.Configuration.BaseConfigurationRecord.ThrowIfInitErrors()
at System.Configuration.ClientConfigurationSystem.EnsureInit(String configKey)
--- End of inner exception stack trace ---
at System.Configuration.ClientConfigurationSystem.PrepareClientConfigSystem(String sectionName)
at System.Configuration.ClientConfigurationSystem.System.Configuration.Internal.IInternalConfigSystem.GetSection(String sectionName)
at System.Configuration.ConfigurationManager.GetSection(String sectionName)
at System.Configuration.PrivilegedConfigurationManager.GetSection(String sectionName)
at System.Diagnostics.DiagnosticsConfiguration.GetConfigSection()
at System.Diagnostics.DiagnosticsConfiguration.Initialize()
at System.Diagnostics.DiagnosticsConfiguration.get_SwitchSettings()
at System.Diagnostics.Switch.InitializeConfigSettings()
at System.Diagnostics.Switch.InitializeWithStatus()
at System.Diagnostics.Switch.get_SwitchSetting()
at System.Diagnostics.TraceSwitch.get_Level()
at TiGra.Diagnostics..ctor() in c:\ASCOM Build\Export\ASCOM.SettingsProvider\ASCOM.SettingsProvider\Diagnostics.cs 73
at TiGra.Diagnostics..cctor() in c:\ASCOM Build\Export\ASCOM.SettingsProvider\ASCOM.SettingsProvider\Diagnostics.cs 60
at TiGra.Diagnostics.TraceWarning(String format, Object items)
at ASCOM.SettingsProvider.set_ApplicationName(String value) in c:\ASCOM Build\Export\ASCOM.SettingsProvider\ASCOM.SettingsProvider\SettingsProvider.cs 79
at ASCOM.SettingsProvider.Initialize(String name, NameValueCollection config) in c:\ASCOM Build\Export\ASCOM.SettingsProvider\ASCOM.SettingsProvider\SettingsProvider.cs 101
at System.Configuration.ApplicationSettingsBase.get_Initializer()
at System.Configuration.ApplicationSettingsBase.CreateSetting(PropertyInfo propInfo)
at System.Configuration.ApplicationSettingsBase.EnsureInitialized()
at System.Configuration.ApplicationSettingsBase.get_Properties()
at System.Configuration.SettingsBase.SetPropertyValueByName(String propertyName, Object propertyValue)
at System.Configuration.SettingsBase.set_Item(String propertyName, Object value)
at System.Configuration.ApplicationSettingsBase.set_Item(String propertyName, Object value)
at ASCOM.ASICamera.Properties.Settings.set_Gain(Int32 value)
at ASCOM.ASICamera.SetupDialogForm.cmdOK_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.3655 (GDR.050727-3600)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
ASCOM.ASICamera
Assembly Version: 6.0.5237.32598
Win32 Version: 6.0.0.5
CodeBase: file:///C:/Program%20Files/Common%20Files/ASCOM/Camera/ASCOM.ASICamera.DLL
ASCOM.DeviceInterfaces
Assembly Version: 6.0.0.0
Win32 Version: 6.1.1.2619
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/ASCOM.DeviceInterfaces/6.0.0.0__565de7938946fba7/ASCOM.DeviceInterfaces.dll
Win32 Version: 2.0.50727.3645 (GDR.050727-3600)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Win32 Version: 2.0.50727.3644 (GDR.050727-3600)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Accessibility
Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
Win32 Version: 2.0.50727.3654 (GDR.050727-3600)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/ASCOM.SettingsProvider/6.0.0.0__565de7938946fba7/ASCOM.SettingsProvider.dll
ASCOM.Attributes
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/ASCOM.Attributes/6.0.0.0__565de7938946fba7/ASCOM.Attributes.dll
ASCOM.Utilities
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/ASCOM.Utilities/6.0.0.0__565de7938946fba7/ASCOM.Utilities.dll
System.Core
Assembly Version: 3.5.0.0
Win32 Version: 3.5.30729.1 built by: SP
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
ASCOM.Exceptions
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/ASCOM.Exceptions/6.0.0.0__565de7938946fba7/ASCOM.Exceptions.dll
System.Web
Win32 Version: 2.0.50727.3658 (GDR.050727-3600)
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
