Tech@ZWO , thanks for that. The problem is that under Autorun it works fine with any exposures of 2 seconds and below. Once I increase exposure time to 180s (3 mins) the image is captured but gets stuck at the loading phase - show Loading in green at bottom right but fails to progress to showing the white bar and transfer speed.
Al settings are as mentioned above except image quality. Shooting RAW does not give an image quality option, Just RAW, MRAW and SRAW. I am using RAW and as stated, this works fine for exposures 120 s and below. I believe image quality only refers to JPEG which I am not shooting.
I have reset the 7D to factory settings and next cloudless night I will test again at 30s, 120s and 180s. I will then report findings here. Out of interest, how long should I wait for loading to complete before aborting the process?
Thanks
Jim
