I'm getting a light area on the right side of my dark frames as well as slight light "spot" in the lower right corner.  This also shows up in all the light frames.  Is this normal?  Do I have a defective camera?  It's not a light leak, the cap was on the camera. For some reason this is difficult to process out as the calibration tends to over-compensate and I end up with a dark spot in the final image.  Attached master dark and Image processed in ASIDeepStack.  Stretched to clearly show the spot and right edge gradient.
Thanks
