The Encoders on my new Ioptron CEM70EC2 Mount cannot be turned off as far as I know. I have been using 2 or 3 secs for Guiding Exposure time, so its bumping the mount too often. From what I understand the Encoders reduce the Mounts PE so it runs accurately and the Guiding Software should only occasionally bump the Mount where needed to keep it in line, someone previously mentioned that using a longer guide exposure makes a lot of sense.
Also what calibration Step and MAX RA and DEC Duration figures should I use on the ASIAIR's Mount setup page?
The current ASIAIR defaults are 2000, 2000, 2000 and I have read that if you are using a ZWO mini Guide scope with FL=120mm these figures should be in the vicinity of 8000 to 10000? I know when you do a calibration, these higher values move the mount more than if you use the default 2000 values and requires less Steps to calibrate. However if you are using an OAG with the FL of the Guider being the same as the FL of the scope, then these figures should be in the range of 250 to 500ms. I would be interested to know your thoughts on all of this.
Also when guiding, what aggression values should I use? I would presume using lower figures such as 10 to 25% would keep the autoguiding bumps down to a minimum? Also with the Guiding Rate, should I try different values 0.25, 0.5, 0.75 x Siderial to see which gives better RMS values or just leave it at 50%?
I forgot to mention that I am currently using a SW ED72 Scope with native focal length, with ZWO guidescope and camera, and once I have sorted out autoguiding my double encoder mount with this setup, I will try autoguiding my C11 with 0.63 Reducer and OAG, so autoguiding will be more critical then.
thanks.
Nick
