I recently purchases this new high-speed colour camera. Numerous issues after installation and trying to use with FIRECAPTURE. Primary issue was camera kept disconnecting, and then would not stay connected long enough to alter settings.
I contacted Torsten from firecapture, who is the author of this program. There is an updated beta version 05, which you need to install from within the firecapture program. So, if, as I did, downloaded the beta version from the website and installed it. You need to then do an update from within the program to get the next version - which caters for the -S series of ZWO cams. Mine now appears to be working fine with firecapture, though I haven't had a chance to try it on my telescope. Thank you Torsten for taking the time to explain this to me, and hope this helps other ZWO camera users.
