Hi Team,
First of all great product. Can you help me with an item. So I have a permanant set up in observatory, and polar alignment gives me the happy face so all good there. I will slew to target and it will take the test shot and then recenter which is fine (great feature) - (Through AsiAir). However recently it has been off quite a bit despite not moving it.
I go to the target e.g. Jupiter manually and then sync. However this sync data is lost on power off so the following night will have to do the same again.
I have check
- Time
- Data
- Location setting
This issue is worse then when trying to do solar as there is nothing to plate solve on. Can you advise if I am missing a step somewhere?
thanks a..
