Hi Team,
With the navigation buttons, could you give the ability to rotate the four buttons in a circular motion... Why?
We when doing a tour of the sky or moor still the moon and you want to bring the crater you are focused on to the left, right or up / down in your shot... it is pot luck which button you use as depends on the tilt of the mount and the angle of your camera.
You could unlock the four buttons as a group, rotate to match your set up and then lock down.
thanks Team.
