Hi - trying to connect to my EAF on a Pi5 using TSX with the 1.5 EAF plug in. When I select settings, I can see that the plug can see the EAF
However, when I try to connect to the EAF I get "The operation failed because there is no connection to the device. Error = 200".
I'm using the 64 bit bookworm OS.
Could you take a look?
thank you,
Colin
