I was out last night trying to photograph different parts of the veil nebular. When I looked this morning all the fit files from the different runs were in the same folder. I thought it would store each run as say NGC6992 then the next as NG6992-1 and so on but it appears not the case. I have noticed in the past that if you start a run, stop it and start again that the files on the 2nd run would be NGC6992-sub. So if you could please modify the system so it saves the files of different runs of the same object in different folders it would help a lot. You could name the folder with the object name and time stamp. Now I have 8Gb of fits files I have to sort out. {Still a great product}
Best regards
