1 Place two Teflon rings. 2 Reverse the EAF support plate. 3 Use the original stop screw and the supplied screw.
luigi67 Thank you for your sharing, does it work fine?
It is very solid and works well. I haven't been able to try it yet, the weather is always bad. I will keep you updated!
luigi67 Thank you very much, we will add it to the EAF supported list if it works fine. That will be helpful for other users.
I finally tried under the sky. It works great and keeps my 3.7kg optical train at its zenith! I am very satisfied and simple to use.
