I had a similar problem, but found the trouble associated with front panel USB jacks.
Using an AMD A8 Windows7 PC, and plugging the ASI120MC into the Front Panel USB2 jack, and a 7 port USB powered external hub, I could not initially get the ASI120MC to work... it would not pass the Device Manager.
It would show Code 1 (not installed) or code 28 (not correctly installed).
Plugging the camera directly into the Rear USB ports, the camera now works fine.
Even plugging the 7 port powered extension hub into the Rear USB port, and the camera into the 7 port extension, the camera works fine.
Even using a very long USB cable works fine.
So let me add this advice if you find a problem PC: try the other USB ports... they apparently can behave differently.
- Michael
