I was having a hard time Polar Aligning and using GOTO on my EQ6RPro. I have the ASI AIR connected to the mount via direct USB (Not ST4 link).
I found that moving the alt knob would also change the az error during PA. And the error values were erratic. Like if I am shown to move 30" to the left, and I move to the left, I get the new error as 69" to the left still. This does not make sense. I should have seen a value less than 30".
In the same way, when using GOTO, even if I synced the mount after a successful plate solve, it would just point to some totally opposite direction. It was a huge pain to use this mount along with the ASI AIR app.
Then out of desperation, I connected the HC to the mount. I was told I did not need to do that as the mount would take the time, date, DST and GPS from the ASI AIR app. After I manually set the time and date onto the HC, everything worked. GOTO and PA both worked. PA was really stable and I was able to get to within 1" of NCP.
So the question that I want to ask is, is there some known or unknown bug that is causing the time and date settings not to be sent to the mount when using the ASI AIR App?
Thanks in advance!
