Haven't had a chance to look at PHD2 user manual yet.
I notice when I start guiding on ASIAir, if your slew rate speed is not already set to "1" (in my case for an AVX mount), the ASIAir will prompt you to select "1" in the dialog box. So choosing 0.5x in the ASIAir Mount section means half the rate as "1"? AVX mount slew speed in the hand controller allows a range of 1 - 9, 9 being the fastest.
Anyone play around with these settings that can provide some advise to these questions?
Does a slower rate, .ie 0.25x mean it would be more precise in holding a certain position?
Does a slower rate, i.e 0.25x mean it would take longer to bring RA and DEC curves closer together on the graph?
What happens if you change this setting on the fly while guiding, eg change from .9x to .25x. The graph shows the RA and Dec are close together now change to the slowest rate to see if it maintains.
Thanks
