Hi i would like to install a remote scope from my other house and i´m using asiair plus. I heared that its possible connecting asiair to vpn port but i would like to know how can i do? which hardware i need and how it´s possible?
thans in advance
The simplest method is to use a router that supports VPN hosting, I use a UniFi Dream Machine Pro for this purpose.
And you connect to Asi air with a VPN IP?
jandruss I connect to the same IP as if I were home once I connect to the VPN, in fact the application scans and picks up the ASIAIR automatically.
Well, i am confusing because i already have the router vpn supported but i don´t know how can i do the vpn connection
