I know this is a bit of an open ended question but when I run my ASI120MC (USB3) at full resolution 1280x960 I am getting around 29fps in FireCapture v2.4 with the following settings:
Overclock set to 15 (I know it can go higher but even with max it is not much different)
USB traffic set to 85 (I know it can go higher but even with max it is not much different)
Exposure 3.9ms
Debayer on or off is the same
I am using a Lenovo Thinkpad with Dual core 2.5Ghz CPU’s, 12GB RAM on USB 3 ports, Intel 7 Series / C216 Chipset Family USB Enhanced Host Controller.
Does this sound correct as I thought it would be closer to 50-60fps, the advertised is 60fps but appreciate that may be a theoretical limit?
Thanks
