As a serious imager who leaves my rig on overnight and unattended while I do other things, often with the ASIAIR app running on an ipad or a screen in the corner, I would like a method to do dock the guiding graph to the bottom of the main window while running, so that I can have a better idea of what is going on.
Whereas the histogram takes up the whole bottom but you only check it during a run, the guide graph is tiny and you check it all the time. This seems backwards.
The existing solution is either: a) ONLY view a large guide graph, or b) view a TINY guide graph and the images.
I add pictures of the current solution, and my proposed solution.
