Hi, I started to operate my AM5 two weeks ago. I am still going down the learning curve to optimise guiding and PA process. A few days ago I started to receive an error while I was starting NINA stating something like " there is 3600s time difference between the mount and the PC, ..." pointing that there will be problem for GOTO. Indeed the first goto is off by a consistent 15°. Once resynchronized it works properly for the following goto.
I have looked for everything I can imagine on the PC (still the same before and after the problem appeared) like bad time zone, bad summer time setup, etc etc I have found nothing. I clicked on the the SYNC from PC to mount in the advanced setup of the AM5 driver. The problem stays the same.
Does anybody have an idea on where it might come from?
CS and happy new year, Frédéric
