Hello! How do I physically connect the ASIAir Pro to an Astro-Physics Mach1GTO mount with a CP3 control box?What type of cable should I use? Where do the two ends plug into? Can I assume that once the cable is set up, the mount will be fully controlled by ASIAir Pro, including polar alignment? Thanks for your kind replies!
