I have 2 AM5 mounts which I would like to run via 2 instances of NINA from the same PC.
Both have a unique serial number, and each connects to different COM port.
However, if I connect Mount#1 to NINA#1, the start NINA#2 and try to connect the mount, it automatically connects to Mount#1, and does not give any option for connectimng to Mount#2.
So, question: Does the AM5 ASCOM driver support multiple instances, so that two mounts can be run from the same PC?
