Thanks John, the feedback is appreciated, but I am well aware of the alternatives.
The point of my post was that it is in ZWO's interest to reduce the occasions where I might want to start looking at these alternatives. Why? Because these alternatives, in addition to having features that led me to start looking at them, also do not entail vendor lock-in. Hence my point that this is bad for ZWO but maybe not so much for me.
I think you missed the point of my post, but in the process, you helped to make my point. 😉
While the ASIAir is not an open platform "mini-PC"; it very much is a "mini-PC". It's an ARM based platform running the Linux operating system. In fact, the newer versions of the ASIAir Plus appear to be quite powerful given their limited power requirements.
I'm not confused that the ASIAir is a closed platform. I choose it specifically because of that. So, you'll notice that my original post made no request that ZWO open it up to allowing me to install ad hoc software. I think this would be a terrible mistake and would reduce its reliability as an appliance.
My request was pretty specific. Either:
1) integrate ASIAir + ASIStudio so I get the greater benefits of ASIStudio (assuming they continue to build this platform out) OR
2) continue to enhance ASIAir so I have no reason to look elsewhere.
The implication being that if I look elsewhere, then I'm no longer locked into ZWO.
I don't agree that integrating ASIStudio with ASIAir would limit functionality to ASIAir's features. I'm not sure why that would be the case? As I mentioned above, ASIAir is based on a general purpose ARM chip running a general purpose operating system, Linux. It's not like they designed a custom ASIC for astrophotography... that would probably be awesome, but very limiting.... and the ASIAir would then cost quite a bit more. So, anyways, my point is they have a fairly flexible platform... a mini-pc... that just happens to be setup to run only their software. So, yeah, they could allow tight integration between ASIAir and ASIStudio if they wanted to put in the engineering effort.
But why do that at all? Well, I would actually prefer they just continue to enhance ASIAir and ASIStudio doesn't offer any benefits. But I think there's a practical reason why I might want both. My Apple M1 Pro powered laptop is insanely more powerful than the ARM chip in the ASIAir (though they share a common heritage). So, ASIStudio could do things that require far more horsepower than might be practical on the Air. It would be nice to have a seamless choice. If I'm running light, I have everything setup on my telescope already plugged into my Air. If I need more heavy lifting, I fire up my ASIStudio and it discovers the Air already plugged into everything and allows me to command the cameras (etc) so from my laptop, where I can then use my more powerful CPU to do whatever it is that's beyond the computational capabilities of the ASIAir... assuming there currently are such things.
Anyways, I'm not a product manager for ZWO, so it's up to them to figure out the feature set that will continue to incentivize me to remain a pure ZWO setup... I'm just suggesting that offering a greater feature set in Studio while not also creating a case where I am incentivized to continue to use my Air with it opens me up to using hardware that comes in colors other than red.
johnpd
