with my old Dell D610 laptop i can slide the usb traffic switch up to 90 which will increase the amount of fps i can get, but with my desktop i can only go as high as 55, if i go higher the screen freezes and you can get a message that says capture fail.
easiest way to get more fps is to use the ROI frame size to just over the target you want, the smaller the frame size the faster the fps without moving the usb traffic slider
