Seestar used to work well with 2.5ghz wifi in the station mode. Tonight, it couldn't find a 2.5Ghz wifi network and kept connecting to 5Ghz wifi hotspot even after I explicitly switched to 2.5Ghz for the station mode.
I need to connect to 2.5Ghz wifi hotspot because I want to share the 2.5Ghz wifi hotspot with asiair plus which doesn't support 5Ghz wifi in the station mode.
When I am out in the field (away from home), I use a small wifi hotspot (supporting both bands) and connect both seestar and asiair plus to the hotspot. This used to work very well before tonight (before the firmware update) with both devices connected to 2.5Ghz. This way, I can control both devices without having to switch between two wifi networks.
However, this stopped working because Seestar can't find any connect to 2.5Ghz wifi in the station mode.
Please, take a look at this issue and make 2.5Ghz wifi work again in the station mode.
Thank you
