I have a router with a 2.4Ghz and a 5Hz SSID. After connecting network to the Sestar S50 with 5Ghz direct connection and Station mode Off, I want to set the Station Mode to use the 5Ghz router connection. What happens when I set Station Mode to On even though I have 5Hz set as the frequency and the direct connection to the Seestar shows as 5Ghz is baffling. When station mode is turned on the Seestar app shows the 2.4Ghz network and auto connects to the 2.4Ghz connection. It refuses to use any 5Ghz SSID network, not even displaying any 5ZGhz SSIDs. How do I force Seestar app to detect, display and eventually connect to 5 GHz as Station Mode is activated?
