hello I am a newbie in this hobby and i have a trouble with zwo guide camera asi120mm mini.
I've only used this device three or four times, and it worked well for the last shoot. And when I tried to use it again a few days later, an issue arose where the camera did not work.
As instructed in the warning, I tried replacing the USB cable and turning the power off and on, but the symptoms are the same. I would like to receive help on how to solve this problem. thank you
