On "Autorun" there is a switch "group by slots". Unfortunately I could not find that setting on "Plan". Is it possible to disable grouping when using a "Plan"?
With grouping I mean, all L (light) frames are done. Then all R (red) frames, then all G (green) frames, etc. That's stupid because if for example clouds go through it can happen that you do not have any good - let's say G - frames. Also you do have different gradients for every channel. In my humble opinion the only right way to do mono imaging with an electronic filter wheel is one frame L then one frame R and so on through all channels and then start over with L. I really do not understand why ZWO implemented it that way. What do you think?
