Have just purchased a FF65 telescope. I want to attach it to my Nikon camera. I have the T ring adapter attached to the camera. What adapters do I now need to attach the camera to the telescope, there are 3 in box. Do I remove anything from the telescope ?
thank you in advance for instruction.
To attach your Nikon camera to the telescope, you will need a T-ring adapter and a T-adapter. The T-ring adapter attaches to your camera and the T-adapter attaches to the telescope. The T-ring adapter and T-adapter should be compatible with your specific model of camera and telescope.
Here are the steps to attach your camera to the telescope:
Screw the T-ring adapter onto your Nikon camera.
Remove the lens from your camera body.
Attach the T-adapter to the telescope.
Insert the T-ring adapter into the T-adapter.
Tighten the thumbscrew on the side of the focuser to ensure the camera does not slip out during use.
You should not need to remove anything from the telescope to attach your camera.
