denababy
Equipment
- Mount: AM5 mount on a T40 tripod
- OTA/Telescope: Sharpstar 94 edph
- If used, Reducer/Flattener: Sharpstar field flattener/ reducer specific one for my scope
- Main Camera: ZWO 2600mc pro camera
- If used, Guide Scope: skywatcher evo guide scope
- If used, Guide Camera: ZWO 120 mini
- Any other equipment (EAF, EFW, Dew heaters, etc): ZWO EAF, two dew heaters one on the main scope the other one my guide scope
- ASIAIR model and firmware version: ASIAIR Plus I’m not sure of the firmware version
USB/Data Cable Connections and Power Connections (9. and 10.)
For connections I use the relevant cables that came usually they have usb connectors that go into the ASIAIR, with the various pieces of kit also for main power I use the Sparking cable. Power is two Jackery 240 batteries
Screenshots of issue and main camera settings
Please look at a previous post and there is a screen shot of one of the images. Main camera settings are/ were gain 100 exposure 120 seconds and a tides turned on.
I’m not on my laptop so screen shots of the aap are not possible.
Just to confirm from points 2 and 3: are you running at f/5.5 with a focal length of 517mm?
When you are next able to - could you try taking a shot in Preview Mode? Make sure not to zoom in on the picture or anything. Once the shot is done - take a screenshot of the whole ASIAIR screen. It would look like the following (just with the image you took instead of the default background):
This way we can see exactly what you are seeing as well as see what firmware version you are running, the gain of the camera, the temperature of the camera and the histogram distribution. You could also have the Guide Graph showing as well.
Also take a few screenshots of the Main Camera settings like this:
Thanks.
