Hi Chris,
those settings should work with the Native ZWO ASI driver I see you use 2.3.1h, and it should work ok.
With the zwo asi driver, I set in the brains camera gain at 94 and the exposure time (near the guide button) to 3 seconds.
The remaining setting are as those ones:
This works ok for my setup, EOS 1100D Meade LS6" (AltAz mount) guided with the 120MC attached to a 70/210mm OM Lens.
No guaranty that they will work with your setup....
May be you can check if your ASICAMERA ASCOM SETUP is the latest version ? V1.0.0.8 earlier version could cause problems.
I presume that your PA is ok and the scope is leveled ok? (other-way you should have the same problem with the WDM driver).
Other ideas and suggestion I do not have at the present time, my knowledge of guiding and the ASI setup is quite recent and a bit limited.....
Clear skies
Marco
