Hi
I have an IEQ45GTN ioptron mount and recently connected my Asiair plus to it. Unfortunately when it comes to the PA procedure, it won’t travel to the 60 degrees step and won’t track. Also the left, right, up and down buttons don’t move the mount, although if I select goto an object it does so fine, and moves manually ok with the hand controller. Any ideas anyone?.
Thanks
