Still doesn’t make any sense. You can move anywhere in the sky atlas and tell it to go there and the scope goes there, so still don’t understand when you would use it. Only possible purpose is if the scope fails to plate solve (and it does happen) but when you start imaging it looks like you are where you pointed the atlas, you can go back to the atlas and press sync to tell the scope it really is pointing at the location the sky atlas is centered on. Is that the use case for using it? I’d like some confirmation from ZWO that is its intended purpose. 🤷🏻♂️
