Ok so as a follow up to this thread I raised a while back. I was reading a thread in an Astro forum about using an IR Filter to reduce atmospheric turbulence when imaging the Moon.
http://stargazerslounge.com/topic/227139-humboldt-crater-with-surroundings/
Now I have a ZWO ASI 120MC (USB3) which I believe comes with a built in IR Filter. Further down the thread someone mentions if you have a colour camera you need to remove the existing IR filter first?
I then came across this link on the website from where I purchased my ASI 120MC from:
ZWO Infrared IR Cut-Off Filter (31.7mm, 1.25")
http://www.365astronomy.com/zwo-infrared-ir-cutoff-filter-317mm-125-p-3567.html
If I purchase and then screw the Cut Off filter on do I still need to remove the built in filter?
I guess I do but the description of the item does not suggest that this is required.
But then will I not simply have two IR Filters which is probably not sensible?
I really don’t want to tamper with my camera if I can avoid it.
Thanks
